Transmission direct to rear end.>? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-25-2014, 04:08 PM
Banned
here is a few more
ID:	115970   Click image for larger version
ID:	115978   Click image for larger version
ID:	115986   Click image for larger version
ID:	115994   Click image for larger version
  #17 (permalink)
Old 01-25-2014, 07:09 PM
BFalfa55's Avatar
There is an S-10 that has been running around my area for about 20 years and it has a Toronado trans axle. He used widened flares on the rear wheels to make up for the wider stance. Everyone suggesting that is probably the best, easiet way.
  #18 (permalink)
Old 01-26-2014, 05:33 AM
There was a mid engined VW Bus in hotrod magazine some years back that had the engine trans and rear end mounted on a swing arm.
Shane
  #19 (permalink)
Old 02-03-2014, 09:08 PM
RAYFIN's Avatar
Last journal entry: before picture
Use a '66 to '76 Toronado or Eldorado transaxle. I agree. They used these to put v8's in the rear seat of Corvairs.
  #20 (permalink)
Old 02-04-2014, 08:10 AM
Another option, perhaps not for you, is a Porsche G50 transaxle. They modify these to be put in sandrails and kit built supercars, to take 450hp+ from american V8s. This isn't the cheapest route, and it is a manual. Another option would be a Corvair transaxle driven backwards. I know street cars on street tires can put 400hp through them for tens of thousands of miles, as long as you're not doing holeshots and burnouts.
We did a design for a supercar builder looking for "1200hp in a rear biased AWD platform" which never materialized; and another one for a replacement, all new T/axle for the GT40/ Ford GT and GT40-type kit car market; which again ran out of money before it got off the ground.
Here's an interesting thread on using transaxles for "loCost" mid engined variants
http://www.locostusa.com/forums/viewtopic.php?t=3293
  #21 (permalink)
Old 02-04-2014, 09:27 AM
Y-Blockhead's Avatar
Most used the Corvair Saginaw 4 speed adapted to a SBC which could also be a good choice for a transaxle for the rear engined S-10.
  #22 (permalink)
Old 02-04-2014, 10:05 AM
Banned
c6 transaxle and tube
The Following User Says Thank You to gearheadslife For This Useful Post:
AutoGear (02-04-2014)
  #23 (permalink)
Old 02-05-2014, 10:35 AM
C5, C6 and C7 torque tube and transaxle
You could also use the front clip off of a 1993+ Cadillac FWD car with the 275hp or 300hp Northstar DOHC 4.6 engine and 4T80e transaxle and install it at the back.
Someone built a mid 90's Cadillac STS that has the 2 sets of engine/transaxle, 1 set up front and the other set in the rear. I dont remember if the rear whelles steered or if they were locked out in the straight neutral position.
peace
Hog
Which Transmission/rear end brian720 Transmission - Rearend 3 03-23-2012 11:52 AM
Which model and year rear end is a direct plug and play? roach4047 Transmission - Rearend 10 08-18-2010 11:51 AM
Transmission or rear end noise classiccamaro Transmission - Rearend 0 09-04-2007 10:53 PM
rear-end or transmission ????????? ss crazy Transmission - Rearend 11 12-04-2002 08:30 PM
transmission or rear end markiemyster Hotrodders' Lounge 0 10-13-2002 05:04 PM
