Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - transmission and driveline tunnel
Old 03-20-2002, 08:30 AM
57Chevyman 57Chevyman is offline
If you can not weld it poprivets are fine. I have fixes lots of floors with tin and poprivets. They work well, just not as pretty as a neat weld job. Just make sure that you seal up the seam to keep moisture out and prevent rust.
Good Luck
