Transmission fluid - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2014, 10:19 AM
Transmission fluid
How many quart are in a 350 transmission and 350 engine including the torque converter
Old 02-04-2014, 10:41 AM
Banned
depends with or without tranny cooler, and with stock 12" converter or aftermarket 12-11-10-9-8" converter
Old 02-04-2014, 11:44 AM
With the cooler and the iam not sure the converter size do you know the Minuit amount then I could go from there
Old 02-04-2014, 10:49 PM
Burnt out transmission tech.
8 - 10. Dump four in. Fire it up. Add until it is at the full mark.
transmission fluid Question rk0982 Transmission - Rearend 20 11-28-2010 02:30 AM
Transmission fluid pressure sexypizzaman Transmission - Rearend 2 05-06-2008 09:54 PM
transmission fluid temperature nixwillys Transmission - Rearend 1 04-16-2006 01:03 PM
Transmission Fluid c-4 85stangboy Transmission - Rearend 9 12-21-2004 07:15 PM
How Much Transmission Fluid? EazyDuzIt102 Transmission - Rearend 8 01-12-2004 03:28 AM
