Transmission fluid in ford ranger R&P?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2012, 07:27 PM
hey guys, I posted a while back in this forum about my ford ranger rack and pinion mated to a gm saginaw pump. I ended up putting on the manual pressure reducer which allows me to control all of the pressure in the steering system. The only thing I have left that I can think of that is still giving me my problems, is the power steering fluid. When I removed the rack from the ranger it had ATF fluid in it. I am currently running normal power steering fluid through the system. Could this be part of my issue as to why I am getting the "herky jerky" motion I am still experiencing. I know that the system is bled out, so I am thinking it could possibly be something with the fluid system. any help would be appreciated
cory
what transmission in 86 ford ranger 1.3l 2wheel drive chevynut1 Transmission - Rearend 3 11-30-2011 10:13 AM
Ford Ranger truck transmission Marinus 57 Transmission - Rearend 7 04-07-2007 04:51 PM
93 Ford Ranger Manual Transmission problems Triaflo Transmission - Rearend 1 08-28-2005 07:58 PM
fluid capacity of a ford C6 Transmission Dubz Transmission - Rearend 4 12-13-2003 11:10 AM
Ford Ranger V8 Conversion Transmission Questions nightrain_rod Transmission - Rearend 3 06-24-2003 05:56 PM
