Hotrodders Bulletin Board
#20
Very many cars with computers will send a TCC code which could be several things besides the converter. But keep in mind the converter is where most of the trans heat is generated. The more it slips the more heat. Your trans requires a lock up converter, but if it is not locking up properly it will generate excessive heat and soon burn the clutch in the converter. |
#21
TCI say's that most 4l60e problems can be connected to electrical or ECU problems. With your year tranny, you need a scanner to extract hard or intermitant codes. Have you had this done yet?
#22
After much investigation, I honestly think the fluid is not getting hot. We added a transmission cooler and still having the same problem. We don't tow anything either. I still need to check temp with a gauge probably Saturday. Thanks |
#23
Temperature question
Could you tell me what the normal operating temperature should be? Thanks |
#24
From TCI's web site...
"The ideal operating temperature for automatic transmission fluid is between 175 and 225° F." |
Back to top |
Similar Threads for: "Transmission fluid hot"
| Best Type F transmission fluid out there? | 84Z | Transmission - Rearend | 3 | 05-11-2006 07:43 AM |
| transmission fluid temperature | nixwillys | Transmission - Rearend | 1 | 04-16-2006 12:03 PM |
| Hotrodders Knowledge Base: Transmission - Rearend | Jon | Transmission - Rearend | 0 | 11-26-2005 05:23 PM |
| Automatic Transmission Fluid Type A | jimra1944 | Transmission - Rearend | 2 | 11-21-2005 01:31 AM |
| Hot Rod w/ a Japanese engine and transmission and a passanger car frame | alex_0227 | Hotrodding Basics | 27 | 05-28-2005 01:07 AM |
