Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission and flywheel delima concerns
Old 12-18-2012, 05:46 AM
bondo's Avatar
bondo bondo is offline
Originally Posted by mh1984 View Post
The engine is a 2nd gen i think. It has an internal ballance shaft and is a vortec. The rear oil seal is a one piece. Ive read that a 350 flywheel isnt a good thing to use due to the uniqe ballance of the 4.3 . My clutch kit came in today and I ordered it for a 88-90 nv3500 . The nv3500 i have is the first design and the casing is a two piece cast aluminum. The bellhusing is integeral. The nv3500 had a few design changes over the years. New venture was a partnership between chrysler and gm. The transmissions had similar designs and internal workings but one would not cross over to the other due to bellhousing bolt patterns. Im not sure if the internals cold be swaped over though.
Ayuh,.... Is the starter a straight, or staggered pattern,..??
Is the block drilled for Both patterns,..??
What diameter is the clutch,..??
A '94 is Vortec in name only, as the Vortec heads weren't Intro'd till '96...
My Guess is ya need a 14" flywheel, for a '94, 'n Up 4.3l motor...
