Transmission/flywheel Knock - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2007, 03:21 PM
I Have A 1986 350/350 Combo That Has A Knock In Park/neutral. It Does Not Knock In Drive. I Unbolted The The Torque Converter And The Knock Does Not Seem To Be There. The Bolts All Seem To Be Right Length And There Is Good Clearence Does Not Look Like Anything Is Scraping Or Hitting. Can This Be A Broken Flywheel That Only Knocks When Torque Converter Is Bolted Up. Or Is This Something Else. Thanks For Any Advice
Old 07-02-2007, 03:24 PM
jakeshoe's Avatar
Sounds like the flexplate is cracked.
Old 07-02-2007, 04:37 PM
blacklabzeke's Avatar
Yep! I will agree with jakeshoe.
Old 07-03-2007, 08:24 AM
brian0605's Avatar
mostly confused
Last journal entry:
definitely flex plate!!! just had one at work about a month ago on a 4.3l vortec (SBC 350 with 2 cylinder knocked off) that busted the outer starter mounting bolt hole off of the block because of a broken flex plate. Flex plate is a cheap fix. We put another engine in ours,and it's a savanna VAN. Pain in the ole arse. Brian
Knock Knock.....sigh.... JamesRS Engine 8 04-24-2006 05:29 PM
Chevy 350 knock driver side? Help jimenezaldo Engine 18 09-01-2005 04:38 PM
engine knock ikeaguirre14 Engine 3 02-06-2005 06:41 PM
Help!!! Knock, Knock, Knock coming from tranny 70bird Transmission - Rearend 1 05-06-2004 12:30 AM
rod knock? rebuilder? Engine 5 11-01-2002 09:59 PM
