im swaping out a 5.0 from my 87 gt for a 32v dohc 4.6. my question is can i swap my aod parts to a aode case , because they a different bolt patterns . has any one tried this set up before,this is really testing my patience.:smash:
ok I am not sure if I read your your post correctly but here is the easy answer. your car already has aode or 4r70w 4.6 engine difference is 3 bolt starter.... 5.0 only used 2 bolts(screws) find a aode 5.0 case trucks from 95 eara 5.8 351....
your question asked about parts swap some of the gear train will inter-change, but case valve body forward drum(shaft) and pump will not inter-change
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
