-   -   transmission hitting bottom of the cab how can i lower it (http://www.hotrodders.com/forum/transmission-hitting-bottom-cab-how-can-i-lower-226633.html)
swanson1930 11-29-2012 09:43 AM
I have a 30 Ford truck witch I have a 350 and t5 setting in and unfortunately my transmission is hitting on the bottom of the cab I need like a half a inch I have welded 2.5 blocks on my crossmember already and stuck a pile of washers under each side trying to make it work so any help and all help did appreciated
gearheadslife 11-29-2012 09:49 AM
http://www.bartcop.com/jpg/012ham.jpg
BruceKoukalaka 11-29-2012 01:01 PM
How about just raising the cab the 1/2 inch you need?
unclebill 11-29-2012 01:15 PM
put thicker rubber spacers under that cab.
sedanbob 11-29-2012 01:32 PM
The simplest approach in the long run may be to raise the hump in the cab. You lowered the crossmember which didn't give you enough - you can lower the motor mounts which may give you clearance on the floor, but interfere with steering. Raising the cab starts out easy, but will require you also raise the fenders, hood, grille shell. If it's just 1/2" and just a few small spots, that big hammer idea might be the winner. If not, you might be able to cut the hump and add a strip of sheetmetal to each side to raise it what you need.
