transmission hitting bottom of the cab how can i lower it - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2012, 08:43 AM
I have a 30 Ford truck witch I have a 350 and t5 setting in and unfortunately my transmission is hitting on the bottom of the cab I need like a half a inch I have welded 2.5 blocks on my crossmember already and stuck a pile of washers under each side trying to make it work so any help and all help did appreciated
Old 11-29-2012, 08:49 AM
Banned
Old 11-29-2012, 12:01 PM
Last journal entry: Update
How about just raising the cab the 1/2 inch you need?
Old 11-29-2012, 12:15 PM
Last journal entry: 27
put thicker rubber spacers under that cab.
Old 11-29-2012, 12:32 PM
sedanbob's Avatar
The simplest approach in the long run may be to raise the hump in the cab. You lowered the crossmember which didn't give you enough - you can lower the motor mounts which may give you clearance on the floor, but interfere with steering. Raising the cab starts out easy, but will require you also raise the fenders, hood, grille shell. If it's just 1/2" and just a few small spots, that big hammer idea might be the winner. If not, you might be able to cut the hump and add a strip of sheetmetal to each side to raise it what you need.
spindle hitting lower a arm when turning nvmy57 Suspension - Brakes - Steering 1 05-19-2010 11:22 PM
X cab or STD cab for Rod project? matt167 Hotrodding Basics 2 10-18-2009 10:57 AM
Lower compession = lower octane? Arrowhead Engine 8 11-18-2007 05:45 AM
How much lower will the frame lower once the real motor is installed ? Tonythefish Suspension - Brakes - Steering 3 02-05-2007 04:14 PM
hey do i need to brase the cab of my short cab pic up befor lifting it off my frame mopar_101 Body - Exterior 7 07-19-2004 06:28 PM
