Transmission holding ideas - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2010, 10:05 AM
406cu.in. of tire smokin' fun
Last journal entry: 406 Build Thread
Here's an odd question for you. I'm going to be pulling my engine out of my truck this week and don't want to pull the transmission. I was going to use a floorjack to support the front of the transmission while the engine was out, but I've decided to take advantage of the open space and want to pull the truck outside for a thorough cleaning under the hood. Any idea's of what I can do to support it while I move the truck?
By the way, the truck is lowered, so there isn't a whole lot of room to work while it's on the ground. I have some ideas that might work, but I want to think outside the box and listen to other's ideas as well.
If it matters, the truck is a '91 Chevy C1500 reg cab and the transmission is a 700R4.
Old 02-08-2010, 10:58 AM
Probably the easiest would be to build a hanger for it - start with a 2x4 or piece of square steel bar (depending on the room available) that can sit on top of the frame rails in front of the transmission. From this, add pieces on the ends to keep the cross piece from being able to slide off the side of the frame, and add drop-links so that you could bolt it to some of the transmission bolt holes. Building this so that it rests on the frame rails allows you to close the hood if desired - I've seen the same basic idea but with a 2x4 resting on the fenders instead. Can't really give ya any measurements, but "eh, that looks close enough" oughta be just fine for this.
As for supporting the front of a trans without an engine (and not caring about moving the truck), I'll use a plain scissor jack - don't have to worry about hydraulics leaking down with this style.
Old 02-08-2010, 12:29 PM
That sounds something like what I was thinking. Unfortunately, the frame is boxed at the front of the transmission right where I would want it.
I was thinking about using a 2x4 and holding it to the frame with some ratcheting tie down straps. Sort of "ghetto", but it should get the job done.
Old 02-08-2010, 03:16 PM
SSedan64's Avatar
Doesn't have to be fancy. I just use some wire through bellhousing bolt holes attached to firewall, hood hinges, frame etc..
Old 02-08-2010, 03:50 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I have to move vehicles with the trans hanging quite often, (to keep the lift from being tied up), and I usually just use a ratchet strap wrapped around the frame rails and under the trans, you can use a piece of 2x6 or something under it if the strap doesn't get it high enough by itself.
I've used heavy wire through two of the bell housing holes to the wiper motor leg, center hood brace, or even a sturdy bolt hole in the firewall too. The ratchet strap seems to work the best and quickest most of the time though,
Old 02-08-2010, 06:27 PM
Great, thanks guys! Good ideas.
Need help identifying a Borg Warner T-10 transmission Federico Transmission - Rearend 3 08-04-2008 07:39 PM
Transmission fluid problems? Croz Transmission - Rearend 7 12-22-2006 01:37 AM
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
tricks for motor/transmission alignment? killerformula Engine 24 07-03-2004 01:00 AM
