Transmission ID? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2004, 01:38 AM
per per is offline
Transmission ID?
Hi
How can i ID the trans (TH700) Is there a number?
Where can i look?
Per
Old 05-24-2004, 05:45 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
A very simple and short search would have netted you the same results.
This link is to a Transmission Information sticky thread in the Transmission/Rearend forum.
http://www.hotrodders.com/t30771.html
In which this picture is contained.
Along with this text:
[color=yellow]
1 Aluminum Powerglide 14 bolts
2 TH200 Metric 11 bolts
3 TH350 13 bolts
4 TH400 13 bolts
5 TH200-4R 16 bolts
6 TH700-R4, 4L60, 4L60E 16 bolts
7 4L80E 17 bolts[/color]
Old 05-25-2004, 12:25 AM
per per is offline
Thanks, i have seen it.
But is there a number so i can se the year of the trans?
Per
Old 05-25-2004, 06:40 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Yes there is.
For the TH-700R4
It is located on the passenger side near the rear of the pan, on a vertical surface.
Look here for pics and more info.
http://www.highperformancecars.com/crosley/700id.htm
Thanks to Crosley
Old 06-03-2004, 12:02 PM
per per is offline
Thanks just what i was looking fore.
Per
