Transmission ident - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2009, 08:04 PM
Transmission ident
I have come into posession of a "Turbo-hydramatic" transmission which I think came out of an early eighties Olds diesel.It has a tag affixed to the tailshaft housing which says " Turbo Hydramatic" then the following number,81-OT-31012. Anyone have any ideas what it may be, and if it will work in other applications besides Olds Diesel?
Thanks, Patrick
Old 09-04-2009, 11:17 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I would suggest a look clik here
Photo of pan shapes on the page may help you ID this
Old 09-05-2009, 11:27 PM
Wiki Edits: 85
Thanks, Patrick
Most likely a TH400 out of a 1981 Oldsmobile. If it has provision for a speedometer it will bolt up to most BPO motors and work. If no speedometer hole, it is Olds only.
Old 09-07-2009, 11:20 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I had an 82 Olds Delta 88 station wagon that came with a TH-2004R, I remember it because of the shape of the pan.
Taurus transmission glitches... awbazar Transmission - Rearend 9 05-21-2009 05:34 AM
1995 Impala Rebuilt Transmission Shift & Noise Problem Mobbvalous Transmission - Rearend 2 12-31-2008 04:50 PM
More transmission troubles chrisflock Transmission - Rearend 3 08-11-2007 12:07 AM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 07:23 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 04:15 PM
