Transmission Identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2011, 05:29 PM
Which 5 speed Transmission does the 2006 Dodge Charger, 5.7 hemi come with? 545RFE or W5A580????
Old 01-26-2011, 05:35 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
RFE stands for rear wheel drive fully electronic, so that is the automatic, the other designation must be a manual 5 speed
Old 01-26-2011, 06:05 PM
W5A580 is the Mercedes 5 speed automatic.
Just don't know which is attached to the 5.7 hemi
I bought on Ebay. There is a Bar Code on the Xmission,
but don't know what that means. Has a Flang on the Rear of
the xmission where the drive shaft attaches. Thoughts are
it's a Mercedes 5 speed, Guess I'll have to pick the Dodge
Mech's brain. Thanks so much for your response.
Old 01-26-2011, 06:48 PM
LATECH's Avatar
So they are both 5 speed autos then?
Old 01-27-2011, 04:47 AM
tnsmith10's Avatar
when will it rain???
you mentioned in your other thread that it had a cable coming from the trans. the 5-45RFE does not have this, but the 722.6 or W5A580 does for the park lock.
how many bolts hold the pan? 6, its the mercedes trans, if a lot more, 5-45RFE
Old 01-27-2011, 05:35 AM
I'll check....Thanks!!!
Transmission Identification Help trblmker Transmission - Rearend 7 11-10-2009 02:50 AM
Need transmission identification Johnny499 Transmission - Rearend 6 02-28-2008 08:56 PM
Transmission Identification Nvr2fast Transmission - Rearend 3 01-22-2006 04:17 AM
Transmission Identification Fragzem Transmission - Rearend 6 09-04-2004 08:40 AM
transmission identification--350 bettylew Transmission - Rearend 3 11-01-2002 02:23 PM
