Transmission Identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2004, 06:37 PM
Fragzem's Avatar
How can I tell if my TH350 is a lock-up or a non-lockup?
Old 09-03-2004, 06:52 PM
BOBCRMAN@aol.com's Avatar
If it is in the car look for an electrical outlet/hookup on the passenger side of the trans above the pan rail to the rear of the dipstick. If out of the car it will not have a fully splined input shaft. the very front will be smooth with an O-ring
Old 09-03-2004, 07:42 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Sorry Bob, I have a correction.
Note that TH350-C lockup versions can be identified by an electrical plug on the left side of the transmission.
Found here: http://www.novak-adapt.com/knowledge/th350.htm
Old 09-03-2004, 08:02 PM
Yep, been a while and Geezer brain,, sorry
Old 09-03-2004, 08:03 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I am sure you meant to the rear of the shifter linkage on the drivers side?
Old 09-03-2004, 11:44 PM
Fragzem's Avatar
Well I know for sure nothing electrical is hooked up to my transmission.....
And I don't believe it has this pulg..
Anyhoo,
if you don't plug in the plug, would that make a lockup a non-lockup?
Old 09-04-2004, 08:40 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
" No electrical plug" on the tranny case as shown / mentioned means NO lockup.
Good luck , have fun
Anyhoo,
