Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission Issues with a Borg Warner Super T10
Old 08-20-2010, 07:20 PM
cobra48451 cobra48451 is offline
Make sure you have 1 to 1.5 inch free play in the clutch pedal. Does the free play change with temperature? Also make sure you are using the correct oil in the trans. Earlier units used AP 90 most T-5's use ATF, but there are other oils used also.
