Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission Issues with a Borg Warner Super T10
Old 08-23-2010, 09:50 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Shift linkage adjustment..remove the shift rods from the transmission arms and place the levers on the transmission in the neutral position..then place the shifter in the neutral position and lock it into place some of the aftermarket shifters have a provison for a pin to hold the shifter in neutral for adjustment purpose..then adjust the shifter rods so they slip into the holes on the trans shift levers..this may help your issue..
Clear as mud I hope not..
Sam
