transmission leak: - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2008, 02:30 PM
transmission leak:
Hi guys,
i've got a problem with my th350,its just started leaking oil,at first i thought it was the cooler pipes which i've replaced but it still leaks.
It only does it under heavy load not at idle or when up on stands with the wheels clear of the grounds allowing me to get in and start/drive it as i would normally do but it does seem to be coming down the filler neck and dripping on the starter,i cant see any obvious holes so is the pressure building up and blowing the fluid out of the filler neck??,if so why has this suddenly started happening??,someone said it could be the breather blocked??,if so where is the breather located??,sorry for so many questions but hoping someone can help me??,
Many thanks,
Paulie.
Old 10-07-2008, 03:07 PM
SSedan64's Avatar
Breather tube is located on top of trans case just behind bellhousing where the case gets small. Hard to get to.
Old 10-07-2008, 03:10 PM
Thanks for that,are there any websites with pictures or diagrams showing the location that i could look at??,
Many thanks,
paulie.
Old 10-07-2008, 03:17 PM
SSedan64's Avatar
See the tube the comes out and turns 90deg.
Name:	BOP TH350 4WD.jpg
Old 10-07-2008, 03:22 PM
XNTRCI-T's Avatar
AKA Lee in KC
It's the the little nub just above and to the left of the shifter knob is this pic...
Name:	052807 010 w.jpg
Old 10-07-2008, 03:39 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
The vent they are pointing out, most times will have a hose hooked to it that bolts to a upper bell housing bolt. If the transmission is over filled, when the fluid heats up it will expand, and push out of that vent.
If it leaks out on to your garage floor over night, the dip stick "hat" seal(where it goes into the transmission) is bad. The torque converter will drain back down into the pan, and drip out of that seal.
More transmission troubles chrisflock Transmission - Rearend 3 08-10-2007 11:07 PM
transmission stop leak 7Deuce Transmission - Rearend 1 05-17-2007 09:48 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
83 Z28 Transmission - YIKES! crandaz28 Transmission - Rearend 4 11-25-2003 07:43 AM
c4 transmission leak 67mustang Transmission - Rearend 2 11-12-2003 10:09 PM
