Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission leak
Old 09-23-2012, 09:37 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
You either have a crack at the pan rail for the leak at the pan or it is not the pan leaking. Oil can leak from one location , then travel around the edges to drip off some place away from the actual leak
The Following User Says Thank You to Crosley For This Useful Post:
Bobs36ford (09-23-2012)
