Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission leak
Old 09-26-2012, 05:44 AM
Merkur87 Merkur87 is offline
Try to avoid cork gaskets if at all possible. Most are synthetic cork and fluid will bleed through the material itself.
Maybe the problem is not the gasket at all. It could be a torque converter seal leaking, dipstick tube, or cooler line fitting. This can easily be assumed to be a pan gasket leak.
