Transmission leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2012, 08:39 AM
Transmission leak
Hello, I have a th350 transmission with keeps leaking from the speedo housing. I have changed the bullet and put a new drive in but still leaking. Can anyone help pls.
Old 11-25-2012, 09:18 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
There should be an inner lip seal, bullet to gear.
Then a outer o-ring bullet to extension housing.
Old 11-25-2012, 09:34 AM
Thanks for your reply. That's been changed 3 times and still leaks. Is it possible the vent/breather being blocked causing pressure build up and then could force it to leak???
Old 11-25-2012, 10:01 AM
C-10's Avatar
Revolution Calling
Oh yeah, that's a possibility.
Could be a leak at another point running down to a lower point, such as the speedo cable too.
Old 11-25-2012, 10:11 AM
Thanks for your help, I've got a few options to look at now.
Tag
Transmission leak Bobs36ford Transmission - Rearend 17 09-26-2012 05:24 PM
Transmission leak Wildwestshow Transmission - Rearend 1 11-05-2010 05:48 PM
transmission leak: paulie64 Transmission - Rearend 5 10-07-2008 04:39 PM
Transmission Leak EazyDuzIt102 Transmission - Rearend 5 08-13-2006 08:18 PM
transmission leak camay7 Transmission - Rearend 3 07-27-2004 10:20 AM
