Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission Leak
Old 08-12-2006, 11:53 PM
Deuce Deuce is offline
The seal may be damaged ...
I always put a little transmission fluid on the seal before installing the drive shaft.
ALSO ... did you use the same transmission rear extension ? They come is two different sizes ... at least.
I put a large seal housing on a small housing drive shaft and had a leak ...
