-   -   Transmission Leak (http://www.hotrodders.com/forum/transmission-leak-95647.html)
EazyDuzIt102 08-12-2006 04:45 PM
Transmission Leak
I just installed a new TH400 Tranny on my 65 Impala.I noticed that there is a slow drip of tranny fluid where the driveshaft goes into the tranny.Did I do something wrong?Any help is appreciated.Thanks,
Eazy
EazyDuzIt102 08-12-2006 11:26 PM
Anyone have any suggestions :confused: ?
Deuce 08-12-2006 11:53 PM
The seal may be damaged ...
I always put a little transmission fluid on the seal before installing the drive shaft.
ALSO ... did you use the same transmission rear extension ? They come is two different sizes ... at least.
http://www.flash.net/~partzman/23.TRANSC400TH.JPG
I put a large seal housing on a small housing drive shaft and had a leak ...
EazyDuzIt102 08-13-2006 10:05 AM
Well I had a Th400 in my car and the tranny went out.So I bought another th400.The tranny I put in is identical to the old one.So you think its the rear seal?
Jmark 08-13-2006 02:14 PM
It could be the rear seal. Was the new trans rebuilt or a used one? Was the rear extension housing bushing changed too? along with the seal?
red_rider52 08-13-2006 07:18 PM
If the seal is not new I would change it. Very cheap and easy to do, and go from there.
