transmission leaking - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2006, 09:08 AM
Marcel
Last journal entry: Choo-choo town
My granddaughter's 1976 jeep commando has a trans leak. It work and shifts fine, I haven't seen it yet, but what should I look for (where) straight 6 auto ,four wheel drive. She says the underside is coated with oil and on the exhaust system. She notated smoke coming from under the veh. any help would be app. Marcel
PS its almost a qt. low on fluid.
Old 10-31-2006, 02:06 PM
airworld2's Avatar
jeep
should be an old 400 trans, you didnt give alot of info, but cooler lines, front seal, and worst case front drive shaft can break loose and whack the case and break out a chunk. along with some other places it can leak.
airworld2
Old 10-31-2006, 02:46 PM
Marcel
the jeep
Thanks for a place to start. I think I'll swap with her and let her drive my Blazer (99) while I try looking it over (or under) I've swapped some chevy trans's auto and rebuilt 4 speeding, but I never even looked under a jeep. The car is fairly new to her (had it about 3 mos.) I did have a new set of tires put on it. its clean as a pin inside and out (142,000mi.) I don't mind paying someone to fix it, I just don't care to hear the 1400.00 $ repair bill on a trans that drives and shifts great. thank again and I let you know what I find.
Old 10-31-2006, 03:10 PM
Jmark's Avatar
If its coated and smoking off the exhaust, it shouldn't be too hard to find! LOL
Mark
Old 11-02-2006, 02:31 PM
Marcel
trans leak
Jmark, you must be so great. I bet you walk outside when its raining and look up and say, wow, that rain is coming from that one cloud right there.
I found the leak, (it wasn't the exhaust tho) but only after get it on a lift and pressure washing the under carriage and starting it. It was only a loose line. Thanks to most of you guys
Leaking 1940 Ford Transmission CSammon Transmission - Rearend 4 05-10-2006 09:42 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
leaking transmission cooler lines crshrmn3 Transmission - Rearend 5 08-27-2003 07:26 AM
Turbo 350 Transmission Leaking 63 vette Transmission - Rearend 2 02-19-2003 05:02 PM
transmission leaking tonylsg Transmission - Rearend 4 12-17-2002 04:27 PM
