transmission leaking - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2013, 07:15 PM
greyghost85's Avatar
i have a 1985 chevy truck with a 700r4 transmission, i noticed today that transmission fluid was leaking out of the yoke off the transmission to the drive shaft. can yall tell me why it would leak and what or how to replace it?
thanks
Old 06-29-2013, 08:16 PM
Banned
the seal is worn, take off the drive shaft, remove the seal on the trans and replace. check fluid level after all is reinstalled.
Old 06-30-2013, 12:24 PM
pricesgarages's Avatar
theres two ways to fix it weld or epoxy the hole in the yoke or remove ext housing there s a sleve with a oring or should be any ways its located beteen the speedo gear and yoke replacing the output shaft seal will not fix the leak if that sleve is missing
Old 07-02-2013, 10:30 PM
yeah we took the housing off and couldnt figure out how to get sleeve off to replace oring, although, the oring from what i could see looked good, no nicks or tears. i replaced the shaft seal and the bushing. will sealing the hole on the yoke cause any problems?
and can someone tell me how to take off the sleeve to replace oring?
thanks
Old 07-02-2013, 11:32 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
thanks
You dont remove the sleeve to replace the O-ring. Pull O-ring out with a hook shaped pointed scribe tool. Replace with new O-ring
New Transmission Leaking SmokeShow01 Transmission - Rearend 2 07-27-2009 06:20 PM
transmission leaking lanierledford Transmission - Rearend 4 11-02-2006 03:31 PM
Leaking Transmission 66chevy2ss Transmission - Rearend 24 08-15-2003 08:13 PM
transmission leaking tonylsg Transmission - Rearend 4 12-17-2002 05:27 PM
