Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission leaking again
Old 02-13-2013, 06:04 PM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Use a cork gasket and 3M weatherstrip adhesive instead of RTV or silicone. Make sure all surfaces are clean, really clean. Don't overtighten the bolts. Make sure the pan flange is flat and the bolt holes are not deformed. If they are, flatten them back out with a small hammer. Are you using a stamped pan or an aftermarket aluminum? I prefer the heavier aluminum style myself.
