Transmission leaking again - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2013, 05:56 PM
I'm looking for suggestions for my transmission pan gasket. The last two times, I have used rubber. And twice it has leaked on the thin side(th350 has a thin wall pan surface on the gear shift side).
Any ideas would be appreciated....rubber, cork, silicone, any combinations thereof.
Thanks
Willy
Old 02-13-2013, 06:04 PM
S10 Racer's Avatar
http://www.warsprints.com
Use a cork gasket and 3M weatherstrip adhesive instead of RTV or silicone. Make sure all surfaces are clean, really clean. Don't overtighten the bolts. Make sure the pan flange is flat and the bolt holes are not deformed. If they are, flatten them back out with a small hammer. Are you using a stamped pan or an aftermarket aluminum? I prefer the heavier aluminum style myself.
Old 02-13-2013, 08:41 PM
It is the original pan. And I bought some 3m weatherstripping adhesive a few days ago for another project so I really like what you're saying.
Old 02-14-2013, 01:29 PM
Last journal entry: No Progress
I agree with S10 racer, just be sure not to use too much adhesive so it can not get inside the trans.
Old 02-15-2013, 09:37 PM
After further inspection, I just found that my leak is from the transmission dip stick port. Any recommendations for sealing?
Old 02-16-2013, 01:24 PM
prostreet6t9's Avatar
Differential/Driveline
Replace the boot or o-ring.
Old 02-16-2013, 01:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
FWIW I have had much better results using the later-style "boot" seal than the earlier O-ring type seal. IIRC the last one I did used the late boot seal and the early O-ring dipstick, but check to be sure the tube fits tightly into the later boot seal if the tube is the earlier O-ring type.
Be sure the retaining tab that holds the tube in isn't bent from removing the engine and trans w/the tube in place. If it is bent, just tweak it back so you can reinstall it w/o the bracket causing the tube to be forced out of position from the bracket being bent.
Later "boot" seal:
Old 02-16-2013, 02:37 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Talked to a friend just now, he remembers me having to use a later tube w/the boot seal- but that the later boot seal AND tube fit the earlier case.
Old 02-18-2013, 01:08 PM
SSedan64's Avatar
X2^^, O-ring type tube always leaked, had to use lots of sealer with it. Boot type tube is much better.
Transmission vent leaking scholman Transmission - Rearend 3 01-16-2011 06:22 AM
New Transmission Leaking SmokeShow01 Transmission - Rearend 2 07-27-2009 05:20 PM
transmission leaking lanierledford Transmission - Rearend 4 11-02-2006 02:31 PM
Leaking Transmission 66chevy2ss Transmission - Rearend 24 08-15-2003 07:13 PM
transmission leaking tonylsg Transmission - Rearend 4 12-17-2002 04:27 PM
