Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission leaks after sitting
Old 09-04-2006, 11:36 AM
Deuce Deuce is offline
It is true that seals will harden, dry up or otherwise leak ... if the vehicle is not driven ...
I have found that the shift arm level is a often the main offender ... and sometimes pan leaks are not pan leaks but in truth ... shift seal leaks.
There is a simple tool to change the seal for most GM automatic transmissions ... PG to 700R4
KD # 2393... I have changed a lot of them and the leak stopped ...
