i want to say its a standard 7/16" line you can get at autozone. you will need a crows foot to remove it from the trans. the th350 and the 700 take the same size lines. you can splice a rubber line with some hose clamps but i wouldnt trust it for too long, at least not without a barbed fitting
Ok so a lit while ago I removed the thread from the transmission...so if I order a standard brake line, how will I manage to get it fit since I'm assuming that it will be straight when I receive it?
Uses 5/16" Inverted Flare fittings/line.
You can get a cheap Tubing Bender to shape the Line or get a Union fitting or Compression fitting to fix the broken Line. http://www.summitracing.com/search/D...?Ns=Rank%7cAsc Classic Tube, Inline Tube & Dorman etc.. sell complete Lines. The Trans Case fitting is 1/4" NPSF/NationalPipeStraightFemale but many replace it with 1/4" NPT/NationalPipeThread. |
| 700R4 transmission cooler line routing. | Scottsdale | Transmission - Rearend | 1 | 01-30-2011 06:36 PM |
| vac line on 700r4 | 64r1 | Transmission - Rearend | 9 | 06-27-2010 10:46 AM |
| transmission cooler line fittings | yragat | Transmission - Rearend | 19 | 02-11-2008 12:23 PM |
| Transmission cooling line pressure 700r4 | grumpy1 | Transmission - Rearend | 4 | 08-22-2007 08:34 PM |
| Transmission Vacum Line | STBR | Transmission - Rearend | 7 | 10-05-2003 09:24 AM |
