Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission Linkage
Old 06-14-2011, 05:20 PM
joe_padavano joe_padavano is online now
The TH350 trans needs two connections, a vacuum hose to the engine to operate the vacuum modulator and a kickdown cable, which is what you've shown in the pictures. The cable needs to be connected to the throttle arm on the carb so that it is pulled at wide open throttle. E-brock sells fittings for their carbs to connect it. The vacuum line just needs to be connected to a port on the intake or the carb that has full manifold vacuum, (ie, maximum suction at idle and none at wide open throttle).
