The TH350 trans needs two connections, a vacuum hose to the engine to operate the vacuum modulator and a kickdown cable, which is what you've shown in the pictures. The cable needs to be connected to the throttle arm on the carb so that it is pulled at wide open throttle. E-brock sells fittings for their carbs to connect it. The vacuum line just needs to be connected to a port on the intake or the carb that has full manifold vacuum, (ie, maximum suction at idle and none at wide open throttle).
| transmission linkage assembly | blinky_1986 | Transmission - Rearend | 1 | 05-31-2009 01:43 AM |
| 1960 Corvette Transmission & Linkage | daveh | Transmission - Rearend | 2 | 05-07-2009 10:41 AM |
| Missing transmission,carb linkage..63 Chrysler 300 Automatic | Mush | Transmission - Rearend | 4 | 06-27-2008 09:11 PM |
| transmission column linkage- 700r4 to a t-350 | frank88chevy | Transmission - Rearend | 1 | 01-02-2008 11:27 AM |
| 1955 Wagon Transmission Problem (Linkage) | morga | Transmission - Rearend | 4 | 08-06-2007 03:53 AM |
