transmission linkage assembly - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2009, 08:35 AM
hit there i need to know the name of the clamp that hold the transmission rod to the shaft for the steering colum i broke it adjusting it due to being seized it is a bolt that screw into a cylinder that is hollow in the middle so the rod can be inserted and the scre titens in to hold in place if anyone knows the correct parts name or where i could find one i would apreciate it thanks in advance
blinky
Old 05-31-2009, 01:43 AM
junior stocker's Avatar
Usually they're referred to as "swivels". They do wear, and they do wear the hole in the levers also. Harded steel, and hard to break.
1995 Impala Rebuilt Transmission Shift & Noise Problem Mobbvalous Transmission - Rearend 2 12-31-2008 03:50 PM
Need help identifying a Borg Warner T-10 transmission Federico Transmission - Rearend 3 08-04-2008 07:39 PM
1991 Chevy Truck transmission seal leak D0UG Transmission - Rearend 5 08-01-2008 07:59 PM
62 Impala column shift linkage ? DADDYOOOOH Transmission - Rearend 3 03-24-2008 09:33 AM
Trans cooler lines which is which atlantis Transmission - Rearend 44 01-08-2006 04:19 PM
