transmission mount - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-16-2006, 04:27 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Originally Posted by johnsongrass1
Have you thought about using a midplate and not using the rear trans mount at all?
Is your four link moving the axle forward enough to jam the driveshaft into the tranny and lifting the trans?
Is the body flexing enough to stress the joint?
I was just thinking of force from the drive shaft into the tranny also...that could very well be part of the problem......
  #17 (permalink)
Old 11-17-2006, 01:04 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
There is no indication of either of these, I mounted one of those cheapo web / video cams under the car and recorded what was going on. Even though the recording was crappy I coudn't identify any issues.
I had thought about body flex, but I do have sub frame connectors and I do not see any indication of flex in all the normal areas (quarters, door jambs, etc..)
  #18 (permalink)
Old 11-17-2006, 01:11 PM
Lost in the 60's
Wiki Edits: 4
In a sitting still level position...........How much inward sliding distance is left on your driveshaft yoke?
  #19 (permalink)
Old 11-17-2006, 04:04 PM
Lonestar's Avatar
When I fitted the driveshaft I gave it 1.25" clearance.
  #20 (permalink)
Old 11-17-2006, 04:35 PM
johnsongrass1's Avatar
Race it, Don't rice it!
What are your upper and lower links lengths?
  #21 (permalink)
Old 11-18-2006, 09:35 AM
Lonestar's Avatar
I appreciate you all being helpful in trying to diagnose this issue, so I will post all my drawings / notes on the set-up. Considering that I recently got my drivers license back after almost 10 years I had plenty of time to play so there are a ton of notes. This will take me some time as my new wife has the house boxed up in storage right now while she is remodeling and painting it. If I missed something in the set-up and you guys spot it that would be great (although I must admit I hate being wrong).
On top of that I have a nasty head cold so I won't be going out to the shop to get actual measurements right now AND we are leaving tonight for a week down in Raleigh for Thanksgiving.
If memory serves me correctly, the uppers were appx. 24" and the lowers were appx. 32". Both do have 1" of adjustment available.
As far as installing motor plates, I do not want to do that as I do not plan on keeping this engine in the car forever. I intend on using this car for a variety of different engines, including a stroked Buick so using plates would severely complicate things. This vehicle needs to be a "universal" type set-up for this reason.
When I get back I will spend some time going through my notes and getting them in order so someone other than myself can understand them (I am horrible at documenting things).
  #22 (permalink)
Old 12-04-2006, 07:44 AM
Lonestar's Avatar
Just to let you know that I'm back and will be compiling my paperwork and drawings as soon as possible. With the remodeling going on and the fact the wife wants it done by Christmas I don't know how soon it will be (there's a lot of notes, and the drawings are full scale so they will need to be scaled down), not to mention I have to dig them out of storage.
I went to move the car the other day and for some odd reason it won't go into gear now...haven't had a chance to look at it yet.
Will get some stuff posted asap.
  #23 (permalink)
Old 12-04-2006, 08:02 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Your wife wants remodel finished by Christmas? Did she specify a year?
  #24 (permalink)
Old 12-04-2006, 08:55 PM
Lonestar's Avatar
Put it this way, she almost has a degree in Architecture and she thinks she is a decendent of Frank Loyd Wright. I came home to walls literally torn out a couple of weeks ago.
I guess I was procrastinating too much so she thought she'd help me along.
  #25 (permalink)
Old 12-04-2006, 09:34 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I got a PhD in procrastinating.
good luck,
post back when you can
would a 350 mount to the 94 firebird transmission Amyzblueeyez Engine 2 04-10-2006 11:27 PM
Muncie transmission mount for my 55 2 door banksbrian Transmission - Rearend 4 01-06-2005 03:48 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 04:15 PM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 04:52 PM
Transmission mount arborlis Transmission - Rearend 2 04-14-2003 07:55 PM
