Transmission mount - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2003, 05:58 AM
New Member
Post Transmission mount
Greetings,
I have a 93 corvette engine and transmission that I will soon be installing in my 48 ford pickup. I recently bought a transmission crossmember kit from a hotrod dealer but the rubber mount doesn't fit. The tail shaft on the 700r4 appears to be different than the standard one. Any ideas or suggestions?
Thanks,
Anthony
Old 04-14-2003, 05:23 PM
Post
My 700r uses the same mount as a turbo 350. I use the early type with 2 bolts in the bottom (newer ones use a single stud, I beleive)
Good Luck, Mark
Old 04-14-2003, 06:55 PM
BOBCRMAN@aol.com's Avatar
Post
there are several different tailshafts for the 700-r you just have to find the one that works for you, try a good trans shop.
