Originally Posted by Babyburr
Going to be using TH350 in my T. Is there any reason I would want to use a polyurethane mount? Or, is the regular rubber mount okay?
Thanks
I had an AC Cobra with a rubber mount. The shifter was mounted on the tranny and the shifter moved around too much. The poly mount pretty much stopped that. If it moves then use poly.
