-   -   Transmission mount (http://www.hotrodders.com/forum/transmission-mount-197579.html)
Babyburr 04-30-2011 09:49 PM
Transmission mount
Going to be using TH350 in my T. Is there any reason I would want to use a polyurethane mount? Or, is the regular rubber mount okay?
Thanks
matts37chev 04-30-2011 09:58 PM
rubber is ok
why not use the poly?
snkbyt 04-30-2011 10:02 PM
Thanks
I had an AC Cobra with a rubber mount. The shifter was mounted on the tranny and the shifter moved around too much. The poly mount pretty much stopped that. If it moves then use poly.
