-   -   Transmission mount (http://www.hotrodders.com/forum/transmission-mount-40708.html)
srfzup 06-02-2004 09:54 PM
Transmission mount
What a great resource! I'm building a 32 Ford roadster and I'm in a jam. 350 small block Chevy with a TH350 behind. The tranny mount is about 1/8 maybe 3/16 from lining up with the 2 frame pre-drilled mounting holes. Am considering just elogating the 2 mounting holes. Anything else I can do? Motor mounts are welded and not going forward. Thank you in advance for any advice.
akm 06-02-2004 10:09 PM
i would just elongate them like you said.
troy-curt 06-03-2004 06:26 AM
Like AKM said, just adjust the holes.
Also this should have been posted in the transmission-rearend forum;
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
k2mooch 06-03-2004 09:32 AM
If you're worried about it sliding around in the long holes, you could weld up the old holes and cut new ones to be little more snug.
MoocH
