Transmission mounted cable shifter install - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2008, 04:24 PM
Countilaw's Avatar
Cox Custom Cars
Has anyone installed on of Lokar transmission mounted cable shifter kits?
I am working on a 46 Chev 1/2 ton with a 700R4 automatic. I want to install the above mentioned shifter.
Old 02-07-2008, 07:00 PM
DARK SIDE's Avatar
shifter
Hey . I just put on the same shifter but with the rod ..not cable. Seems to work great. easy install. would use again.
Old 02-08-2008, 07:41 AM
I have not had any experience with a Lokar cable shift, but it should be of the same quality as their other shifters using rods. Their cable/housing for emergency brakes will handle the shifting function just fine. I used a tranny mounted Hurst cable shifter for years without a malfunction and it was still good when I gave it to a fellow rodder for his build.
Trees
Old 02-08-2008, 02:19 PM
DARK SIDE's Avatar
cable
Im using their gas pedal cable with the gas pedal. Also have their kick down cable. Going to get the tranny and motor dip stick too,. All good stuff.
Hurst Shifter Install 383vette Transmission - Rearend 0 04-01-2004 06:32 AM
Hurst Shifter Install 383vette General Rodding Tech 0 04-01-2004 06:18 AM
How hard to install short shifter? Trav Transmission - Rearend 1 11-05-2003 09:54 AM
Install Buckets and Floor Shifter for 70 Chevelle 70chevyss Interior 1 08-06-2003 11:37 AM
Need Help with Transmission install 4.3V6 Spitfire Transmission - Rearend 5 04-17-2003 05:22 PM
