Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission noise
Old 08-14-2012, 09:45 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by jeffysit455 View Post
I'm hearing some whining noise in the transmission when i accelerate in 2nd and 3rd gear. Its a 76 trans am and its sat for awhile so im wondering if it just needs the gear oil changed or what might be the problem? if it is the gear oil how do i go about changing that?
Gear oil is used in manual transmissions... you have a manual trans?
Have you looked for a drain plug on the trans case?
