-   -   Transmission noise (http://www.hotrodders.com/forum/transmission-noise-222906.html)
jeffysit455 08-14-2012 10:42 PM
Transmission noise
I'm hearing some whining noise in the transmission when i accelerate in 2nd and 3rd gear. Its a 76 trans am and its sat for awhile so im wondering if it just needs the gear oil changed or what might be the problem? if it is the gear oil how do i go about changing that?
Crosley 08-14-2012 10:45 PM
Gear oil is used in manual transmissions... you have a manual trans?
Have you looked for a drain plug on the trans case?
jeffysit455 08-14-2012 11:05 PM
yes i do its a 4-spd and i have looked there is a bolt on the side of the case but when i tried to take it out it was really hard and i wasnt even sure if it was the right one so i stopped trying.
