Transmission noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2012, 09:42 PM
Transmission noise
I'm hearing some whining noise in the transmission when i accelerate in 2nd and 3rd gear. Its a 76 trans am and its sat for awhile so im wondering if it just needs the gear oil changed or what might be the problem? if it is the gear oil how do i go about changing that?
Old 08-14-2012, 09:45 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Gear oil is used in manual transmissions... you have a manual trans?
Have you looked for a drain plug on the trans case?
Old 08-14-2012, 10:05 PM
yes i do its a 4-spd and i have looked there is a bolt on the side of the case but when i tried to take it out it was really hard and i wasnt even sure if it was the right one so i stopped trying.
Transmission noise Kchart18 Transmission - Rearend 7 08-19-2006 08:48 AM
Transmission noise Terry Robinett Transmission - Rearend 2 06-21-2006 09:11 PM
Transmission noise Derkyb Transmission - Rearend 1 02-27-2005 09:52 PM
transmission noise marjess113 Transmission - Rearend 1 12-12-2002 03:23 PM
Transmission Noise MHenricks Transmission - Rearend 1 02-16-2002 05:49 PM
