transmission noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2002, 03:57 PM
Arrow transmission noise
i have a 82 chevy c-10 with a 350 motor.today it made a griding noise when i was driving.when i put it in park there was no noise.it's not the u-joint,and it sounded like it came from the tourqe converter.please give me advice of what to do!!
Old 12-12-2002, 04:23 PM
New Member
Post
have you checked to see if the starter has came loose and is hitting the ring gear.also check to see if one of your ring gear bolts have not came loose and is hitting the back of the motor or the dust cover
