transmission numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2012, 10:50 PM
hello all, question for you,, i have a 305 with a stamp on the passenger front engine pad of K071405F been told this is a 83 305 maybe out of a mid 80`s olds cutlass, transmission has 13 bolts that hold the pan on, pan is almost square with one corner cut off so to speak,,the numbers i have found on the trans drivers side are 8641711 just below this number is 10214-A can anyone tell me what year this tranny is or possibley what it may be from, i have been told it could be a buick 350 or an olds 350 or a chevy 350 trans im confused need some help here, it does have the TCC plug in on the left side, i have also been told this could be a turbo 250 trans,,,,,,,,,,,i have tried some internet searching but havent had much luck with ,,,,,,,,please help before i pullout what hair i have left,,,,,,,,,,thanks again
Old 10-29-2012, 03:30 AM
Wiki Edits: 85
Could be a 350C or 250C according to the pan and plug.
ID Numbers. afsog Engine 2 12-12-2010 07:21 AM
Engine casting numbers and vin numbers drfo Engine 5 06-18-2010 05:15 PM
What are do these numbers mean?? jm8541 Transmission - Rearend 2 03-01-2007 01:03 AM
Help with numbers Larry H. General Rodding Tech 3 07-22-2005 04:18 PM
Transmission numbers have me confused brian12c Hotrodding Basics 1 01-25-2005 06:11 PM
