Transmission oil cooler location - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2007, 08:56 PM
What about putting the trans oil cooler under the vehicle? I know some have done it, but what about gravel, other things hitting it? I have very little room for a cooler under the hood, and the radiator has no oil cooler in it.
Where would be the best place for it? Would you do it or not? Thanks.
Old 12-19-2007, 09:05 PM
79C10's Avatar
Viva la Migra!!
How bout back by the gas tank somewhere? I don't know what kind of vehicle it is , but maybe in front of the radiator down low in one corner?? how big is the cooler??
Old 12-19-2007, 09:07 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The air to fluid type of Coolers need air flow to function properly
Radiator Oil Cooler MI2600 Transmission - Rearend 7 09-15-2005 08:06 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
Dodge oil filter location Grusome Goat Engine 0 10-10-2003 07:14 PM
transmission cooler location Adrenaline_Fiend Transmission - Rearend 15 07-31-2003 07:20 PM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
