transmission oil type. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2005, 06:57 AM
Hi,
I have some gear grinding issues with my Doug Nash five speed transmission. It will gear grind when I actually get it out of gear bringing it to neutral. I didn't have this problem with the same transmission before major work on my car including opening the transmission to check it out. The transmission had standard 90 gear oil in it when I took it out but I've refilled it with Castrol 75-90 Syntech oil afterwards and am not sure if this is an acceptable oil for my transmission wich is an older 1986 model but otherwise in good shape.
A strange factor to this problem is that it would occur only once the motor (and transmission I guess) had fully warmed-up....
thanks for helping,
Ronald.
Old 06-04-2005, 08:06 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Different oils do not cause grinding. Gears, sliders, bent shift forks hitting stuff at the wrong time cause grinding.
That is not to say that some trannys work/shift better with syn oil over regular gear oil
gear grinding is an internal problem usually.... IF the shifter is adjusted correctly.
there are detents in the tranny internally that may be fouled up.
If it was worked on recently I would look there first
Originally Posted by TVR383
Hi,
thanks for helping,
Ronald.
Old 06-04-2005, 09:23 PM
After seeing how synthetic wont climb the gears in this test of additives I would never use it.
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Old 06-05-2005, 09:28 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Yet it is odd that several car manufacturers install synthetic oils at the factory now
transmission oil? engineman302 Transmission - Rearend 9 01-10-2005 05:20 PM
No Oil Pressure with normal operating tempature jrm123180 Engine 3 03-03-2004 02:56 PM
oil pressure! motor new, start up 75 lbs ! now1lbs at1400 rpm wantafastpass Hotrodding Basics 6 02-29-2004 11:54 AM
What Brand / type of oil is everyone using Francis Engine 54 08-03-2003 06:57 AM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
