transmission pan gasket???? PG - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2006, 09:36 PM
aztek_warrior's Avatar
I was woundering if anybody knows of a
company who makes a silicone or rubber
gasket for the pan gasket for the aluminum
powerglide??? I've found that the other type
of gaskets don't seal like they should and don't last as long.
(unless something wrong with my tranny)
If anyone knows where i can purchase one let me know.
Thanks for any help...
Also the car is a '63 impala 230cid (stock) mostly a weekend
driver.....I've just found that after a couple months the gasket
starts to leak, couple drops at a time, but drop by drop becomes
a puddle...
Old 06-14-2006, 09:47 PM
we buy ours from APD and they sell the plastic type reusable and the cork style, but 90% of our trans rebuilds get the cork type and our pan gaskets NEVER leak,
the trick is torquing the bolts to 100 in lbs, it doesn't have to be exactly 100 but it is more important that they are all torqued the same and that is is not overtightened and squished out, try borrowing an inch pound torque wrnech
Brendan
Old 06-14-2006, 09:55 PM
And make sure the pan's sealing surface is not bent.
Old 06-15-2006, 03:53 PM
brand new pan, no bends, i'll try and see if i can get a hold
of a torque wrench since i don't have one, maybe thats what
the problem is.....thanks ill keep you posted on results.
Also i had another question where can i purchase some
of the gasket material sheets to make my own gaskets....
i've always wanted to try and make my own, specially since
a lot of the auto parts stores sometimes they don't carry
just that specific gasket that you need.....
Old 06-15-2006, 05:01 PM
You could try giving these guys a call.
feedback on "fast change gaskets"
Old 06-15-2006, 07:56 PM
Classix_Lover's Avatar
Music soothes the soul
Last journal entry: Wiring finished finally
Just use a standard cork gasket. They're cheap and work well. Just be sure to tighten everything in a cirlce motion, not that star pattern like you would when you tighten lug nuts for your wheels, you could warp your pan if you do it via the star pattern. Just snug them up if you can't get a hand on a torque wrench, not too tight though, just a nice snug fit. Be sure to go around the pan 3 times when you're tightening since the gasket will compress and you'll need to tighten it slightly more each pass around, just to get everything tightened evenly.
Old 06-17-2006, 08:48 PM
65Stanger's Avatar
Check the water, check the oil
Go to Kragen or Napa and buy an inch-pounds torque wrench. Torque all the bolts in a circular go-around to 100 inch pounds. It won't leak, guarenteed. =) Torque 'em twice.
(edit: I know someone said it already, but just reaffirming the facts. =) )
350 Chevy oil pan leaking gasket Ed Baltera Engine 14 08-05-2012 02:17 PM
One piece sbc oil pan gasket? jtybt Engine 1 04-26-2006 06:33 AM
New pan gasket without raising engine? rapsag Engine 14 04-21-2006 03:49 PM
Oil pan gasket meschnebly Engine 5 07-08-2005 09:02 PM
Oil Pan Gasket Chevy21 Engine 5 03-02-2005 10:15 PM
