Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission and Pinion Angles
Old 01-10-2013, 12:14 PM
kso's Avatar
kso kso is offline
I don't really understand the degrees-down and degrees-up description...and how that works with the truck being raised...
...but at the heart of it and however the body sits, the centerline of the trans output shaft and the centerline of the pinion shaft need to be parallel with each other as seen from the side.
