Transmission and Pinion Angles
Can some one PLEASE set me straight on setting the proper angles on the output shaft of the transmission and pinion. I have read so many discussions about this and it becomes confusing to understand.
1951 Chevy Pick-up, 700R4, leaf springs, 1972 Chevy truck differential. Everything was fine until I replaced the leaf springs. The original springs were pretty flat and the new ones are bowed properly. I now have a rake to the front end. It now vibrates at 65-70. Previously, I set the transmission at 3* down and the pinion at 3* up and everything was fine. Now, I can't raise the transmission far enough to get to the 3* down position. Currently the transmission is at 7* down. I did not build the truck so I am stuck with what I have. If I raise the transmission any further, I pick up all kinds of rattles and vibrations from the drive line touching the body. Can I keep the transmission at 7* down and set the pinion at 7* up to cancel harmonics? Thanks in advance for your comments. |
I don't really understand the degrees-down and degrees-up description...and how that works with the truck being raised...
...but at the heart of it and however the body sits, the centerline of the trans output shaft and the centerline of the pinion shaft need to be parallel with each other as seen from the side. |
| Pinion Angles and Driveline Setup for the Street | Centerline | Suspension - Brakes - Steering | 32 | 05-11-2007 07:22 PM |
| Pinion angles... | Canzus | Suspension - Brakes - Steering | 5 | 01-05-2005 06:07 PM |
| How to find pinion angles | 53fordguy | Transmission - Rearend | 3 | 12-11-2004 05:38 PM |
| pinion to mount angles on a ford 9 in in a 79 camaro | Jared | Transmission - Rearend | 1 | 09-17-2003 12:11 AM |
| Pinion and tranny angles | zachscc | Transmission - Rearend | 4 | 12-24-2002 10:14 PM |
