Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - transmission and pinion shaft mis-alighnment
Old 05-25-2013, 06:30 AM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Should not be a problem. Ford motor company has used offset pinion rear ends since the fifties with no bad effects.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
GARY HOOTEN (05-26-2013)
