Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - transmission and pinion shaft mis-alighnment
Old 05-25-2013, 09:16 AM
joe_padavano joe_padavano is offline
The output shaft and pinion shaft are offset up and down normally. There's no difference between an offset in that direction and an offset side-to-side. What IS important is that the two shafts need to be parallel.
The Following User Says Thank You to joe_padavano For This Useful Post:
GARY HOOTEN (05-26-2013)
